I have an electrolux range with a gas oven. When I bake a bread product - primarily mixes such as cornbread, brownies, etc, the mix does not rise. Does not matter whether I use convection feature or not. Tastes k - just flat as a pancake.
Hello Lisa - From what you have described it sounds like you either have a faulty oven sensor, mechanical thermostat or EOC. In this case, I would suggest contacting a certified technician to assist in the full diagnosis and repair of you gas range.
When cooking with YEAST, 1st mix the correct amount of FRESH yeast into about 1/2 cup of warm water, according to your recipe. Let the YEAST and water mixture sit for at least 15 minutes or until you see the yeast mixture "bubbling" which will indicate that it's both fresh, alive and working. Let it bubble for awhile, and if it doesn't bubble a lot, add maybe a 1/4 teaspoon of sugar, which is food for the yeast, and then it should start bubbling very quickly. Then you mix it into your batter of whatever recipe you're working with, and let the batter rise at least once in about an hour's time ( covered with a cloth, and sitting in a bowl ). Some recipes call for certain batters to rise to double the batter size once, and then beat it down with your fist, and let it rise again, before baking the stuff.
BROWNIES are something different and don't use yeast but do use baking powder, about one or 1 and a half teaspoons per each "batch", and after all the ingredients are mixed and poured into the baking pan, it can be placed immediately into the oven and cooked, rising about twice as high.
SOURCE: How to clean lower oven of 30" electric range by electrolux
try a lemon heated and the acid will eat away the food
SOURCE: Hi! We have an Electrolux E36DF76EPS. I ran the
I'd check the thermostat for continuity first
Item 119 on this diagram
http://www.searspartsdirect.com/partsdirect/part-model/Electrolux-Parts/Range-Parts/Model-E36DF76EPS/1412/0122007/R0705157/00003?blt=06&prst=0&shdMod=E36DF76EPS
