My monitor just died, so I picked up a used Dell at the thrift store. When buying this monitor I forgot about sound, my HP (dead) monitor had speakers built-in. I know it's a dumb question but does my desktop have built-in speakers? I probably have to purchase some, darn it.
SOURCE: No cable and no sound on speakers for flat screen monitor
Hello Tothelake45,
When you bought your computer, you might have received lot of cables along with it... so find out the cable that has the jacks on both the ends of the cable. The Jack looks like that shown below.
So we are looking for a cable that has a jack at both the ends.. One jack goes into the soundcard of your computer (the green color coded port or the port where you normally connect your desktop speakers or headphones) and the other end goes to the similar connector on the monitor which is color coded as well (green color).
Please let me know if that works and please do not forget to rate the solution.
Thanks and Regards,
Srinivas
SOURCE: Can Dell speakers be used with HP computers?
Well speakers are speakers so to "Speak" ... As long as the INPUT connections are the same, then, there is NO reason why they should not work.
SOURCE: I have a new hp monitor-HP 2011x and have no
You audio may be muted. Go to the control panel and click sound & audio.. Check to see if there's a check in the mute option, if so uncheck it.
