The driver that I had ot along with the scanner is for older version of Windows. Where can I get the driver for Windows XP?
You can register for free on this site, then download the driver for your scanner. http://www.scanner-drivers.com/drivers/77/77791.htm
Hello there. My problem is that I have the cd for the scannere Scan Prisa 640P Acer, but when I start running the program, it says It is not good for it. So, I tried and tried but is not working. And my computer is not recognizing the scanner neither. Before of the Window XP, I had Wisdow 98 and my scanner was working good, the problem was the new program I got.
Hi i am suparnaka i have Acer scanprisa 640P
but i Cant work this scanner Xp os
i want download xp drives pls help me
I also need driver for Acer scanprisa 640p (XP)
Hello there!
I have found the driver download link, hope it works for you as well.
baqir, syed
http://www.lostmydrivers.com/scanner-drivers/acer/acer-scanner-driver-package---mirascan-3424p.html
Get drivers for free at www.driversguide.com
Gracias
por hacer pocible el conseguir los driver para que funcione mi escaner
hoy voy ha poder escanear mas fotos para para guarda mi albun antigua. garias nuevamente.
l want to use Acer Scan Prisa 640P which is not compatible to Window Xp. How will go about?
yes I am having the same problem
I need driver for scanprisa 640P because is for '95 & '98 and now i'm working with XP, icant install it please send me a driver for it: Thanks very much:
Xavier Moreyra
hi, my acer scanprisa 640P flatbed scanner doent work with windows xp, do you have a new driver version for this? thanks
my acer scanprisa 640p flatbed scanner {2000} does not work with winxp
My old {2001} Aser Scanprisa 640p Flatbed Scanner does not work with winxp
old scanner and driver is old windows.
older version of software
i want to acer scanprisa 640p flatbed scanner driver for windows xp
I bought this scanner Acer ScanPrisa 640P in 2001 in South Africa but lost its software cd. I have been unable to use it all along and would like to know how I can get this software. Plz help
Hello, I have acer ScanPrisa 640p but could not work with windows xp. Pls kindly download a driver to enable me use the product. Thanks
your post as a comment to ss29's Driver for Acer scanprisa 640P (XP) problem, and notify you when a new solution is offered.
I am having driver verson 3.40 which is not supported by windows XP Professional, I like to download the latest version. Plese provide.
Please describe the specifics of your problem below. We'll add
my scanner is not working properly i need the driver of the scanner plz tel me who can i find the driver.
regards
I have been asking around, without avail
i have the older version of scanner driver for 640p kindly show & help to find from where i can downlod thedriver for windows xp & vista
I am searching for driver for scan prisa 640P scanner to match with windows XP
Need Drivers for Windows XP for Acer ScanPrisa 640P Flatbed Scanner
No body all over the world can't get XP driver for scanner 640
unbeleiveble
i want scan prisa 640p xp driver
my scanner acer640 P is not working on window XP. Please help me. Thanks
I only have the scanner driver for windows 98..
I need to work with windows XP.
I have the same Acer ScanPrisa 640P flatbed scanner and have not found a driver for Windows 2000 or XP.
Ernie
i lost the software cd for my acer scanprisa 640p.
driver does not work with win xp, where can i download new driver that will work with win xp,urgently needed. thanx a lot.
I am also searching for that acer prisa 640p driver.can you kindly help me?
scan prisa 640p driver for window xp
i need help plz
Hi.. I basically have the same problem : needing a driver for XP. My driver CD is set up for Windows 98, whereas I've upgraded my OS and currently using XP. So I can not use my scanner at all. Can you help? Many thanks.
I HAVE THE SAME PROBLEM
I want to install a driver of scan prisa 640p for window xp.
the driver that I had ot along with the scanner is for older version of Windows. Where can I get the driver for Windows XP?
i too is facing same problem
i also need driver for Acer scanprisa 640p (XP)
