20 Most Recent Acer ScanPrisa 640U Flatbed Scanner Questions & Answers
2answers
Looking for a driver for the Scanprisa 640u for Vista
1) Turn off User Account Control (UAC)
In Win vista Go to:
- Control Panel - User Accounts
a) Click - "Turn user account control on or off"
b) Untick - "Use user account control to help
protect your computer"
Then:
2) Go to driverguide.com and download xp driver for the scanner.
3) Find the setup.exe file in the driver install folder
4) Right click on the file
5) Choose properties
6) Click the Compatibility Tab
7) Tick "Run this program in compatibility mode for" tab
8) Choose "Win Xp Sp2" or the operating system you are using
9) Click "Apply" then "OK"
10) Run "Setup.exe" file
NOTE:
This procedure may be used to run other programs that may have compatibility problems.
4/16/2017 12:48:57 AM • Acer ScanPrisa... • Answered on Apr 16, 2017
MAY I USE SCANPRISA 640U WITH WINDOWS 8.1
There are no drivers for windows 8.1 because it is pretty old model of scanner, only way you can use that scanner is with VueScan Scanner Software VueScan Scanner Software
10/26/2015 7:15:48 AM • Acer ScanPrisa... • Answered on Oct 26, 2015
How to install without cd
first of fall you download mirascan 3424 and then inistall it correctly and then go your control panel click on a add scanner icon add a scanner ofter that you download photofilter and inistall it finish
3/11/2014 1:42:32 PM • Acer ScanPrisa... • Answered on Mar 11, 2014
Driver required for Windows 7
You can find the drivers here.
Try the second one for Windows XP, you may need to run it in compatibility mode, as detailed here.
5/4/2011 11:45:54 AM • Acer ScanPrisa... • Answered on May 04, 2011
Hello, I have a scanprism
Download the scanner drivers from the Acer WEB site. Make sure youselect the model of your scanner and the XP or Vista version of the drivers youthat require and it matches the Windows version that is installed on yourlaptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
3/18/2011 4:02:05 AM • Acer ScanPrisa... • Answered on Mar 18, 2011
2answers
Downloading acer scanprisa 640ut-driver
I want download the driver for my scanner but I could not do it. What should I do? my sistem is XP,tanks elvira
3/7/2011 1:18:32 PM • Acer ScanPrisa... • Answered on Mar 07, 2011
I need driver for scanprisa
2/7/2011 1:54:52 PM • Acer ScanPrisa... • Answered on Feb 07, 2011
Acer 640u won't work with windows 7
Go to:
http://driverscollection.com/?file_id=19052
and download file, then just unzip and install setup.exe and restart computer.
I use win 7 x86 (don't know if it works for x64). copy.pngfavicon.icofavicon.icofavicon.icofavicon.icofavicon.icofavicon.icotrans.png
1/4/2011 2:27:39 PM • Acer ScanPrisa... • Answered on Jan 04, 2011
2answers
I need drivers for FlatbedScanner win 7
It does work for windows 7.
Go to:
and download file, then just unzip and install setup.exe.
Yes, the scanner is rather old, but it sitll does the job.
1/4/2011 2:27:20 PM • Acer ScanPrisa... • Answered on Jan 04, 2011
Necesito los controladores para un Acer ScanPrisa
Estos sirven para win7, los he probado en x86, no se si funcionen en x64:
le da en download file, descomprime e instala setup.exe (es multilenguaje) y reinicia y listo.
Los controladores se instalan bien, pero no creo que le funcionen los programas que instala (muy viejos), le recomiendo que use el ABBYY finereader (muy bueno) para manejar los escaneos, para el OCR (convertir imagen a texto) o escanear imágenes con Photoshop.
Espero que le sirvan.
1/4/2011 2:27:13 PM • Acer ScanPrisa... • Answered on Jan 04, 2011
Acer ScanPrisa 640U Flatbed Scanner Logo
76 questions posted
Top Acer Office Equipment & Supplies Experts
SmartAviator
SmartAviator
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
ScanPrisa Acer
  • ScanPrisa Acer
Most Popular Question
looking driver scanprisa 640u vista
  • Office Equipment & Supplies
