My photo tray used to work perfectly, then all of a sudden stopped working! Each time I load the photo paper in the photo tray it tries to take the paper, but the paper stays in the tray and I get an error message: clear paper jam, then press OK. The only problem is that there doesn't seem to be any paper jam, the photo paper is still in the tray! I've opened the back and looked, but can't see any paper jammed. The main tray works fine. Please help... thanks! Brenda
Check
the following:
Paper
type
Load
up to
this many sheets
Plain paper
Approximately
120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper
Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do
the following:
1. Gently pull any jammed paper out from the output
tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson
Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus
NX400. Open the scanner, remove the jammed paper and torn pieces, close the
scanner, and turn the Epson Stylus NX400 back on.
Thanks for helping... I went to the hp site... but not sure what you meant by f 4235... can u explain?
The main tray prints fine, but the photo paper in the photo tray won't feed. I've restarted the printer, cleaned the rollers and separator pad and it still says there is a paper jam and that I should clear it. Do I need to take it for repair or is there some way I can fix it myself?
printing from other trays are okay but it jams whenever I use the feeder tray
