When I switch from the computer to the TV the PC immediately goes into sleep mode and is unable to come back out of it without switching off the computer.
Please switch to another mode - maybe power save mode before the machine has a chance to reach the point where it goes into sleep mode. Forcing the machine into another mode, should mean that it can't go into sleep mode.
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Try booting into Safe Mode then go into the Control Panel and change the Power Options.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.Once safe mode is up click Start/Control Panel and look for Power Options.
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
I cant find any info on your computer, the company stopped trading in 2008, but you can use some software to check everything about your computer.
I use PC Wizard by CPUID, its free and will tell you everything.
Find it here http://www.cpuid.com/softwares/pc-wizard.html
We turn off the TV. Turned it back on using the tv turner remote that comes with the set, we push the HDMI1 mode button immediately! Must do before it goes to Deep Sleep mode. You should not use RGB mode as this will cause the problem to repeat. (Vizo HD 50") Keep trying if doesn't work the first time. You have to be ready and quick to get the mode HDMI1.
Instead of sleep mode, tyr hibernate. It is generally faster except the whole computer shuts down. When you power back up, you're exactly where you were. Mine takes about 30 seconds.
Are you using an optical mouse? If so, try turning it upside down before entering sleep mode. On some surfaces (with some mice only), the mouse picks up movement even if perfectly still.
