I am unable to Configure the IP address in Konica Minolta di 2510 f all in one Copier Printer. Someone please advise me how to do it. If possible give the steps I will have to follow in configuring the IP address. Kindly mail me the solutio at [email protected]
Select you tube and ask how to set ip address for konicaminolta di 2510
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
