Just was idle and stop try to start back and it would just spin but won't start
Hello
The engine
and automatic transmission in this vehicles drive train
are fully electronically controlled by a computer called the PCM
(Power Train Control Module). Whenever a problem like this occurs the
computer stores a record of the problem (there are of course some
exceptions to this, like the fuel pump, engine coolant temperature
sensor and MAF sensor for instance) in the form of a fault code in
its memory, to read these fault codes you must have the systems
memory scanned with a special tool. Once the fault code(s) are read
you then must perform the appropriate diagnostic testing to find and
resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A
TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR
HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM
Thanks Dennis Died out ,crank won't start. Caused by wire harness inside high pressure pump cover was shorted to ground blowing fuse. Cab off $1884,92 fix
That happened to mine as well. My fix was covered under the extended warranty package I had purchased. I was shown the problem wiring harness as well as the "fix". Ford knew of the problem early on but did not do a recall. They also charged those not under warranty when the wiring harness shorted out. My cab was pulled 3 times due to oil leaks after the fix.
