I've just been given an ACER ASPIRE 5742 to take a look at. There is no windows on it and there are no recovery disks for it either. I'm trying 2 do a factory restore. I'm trying the Alt + f10 command, all I get up in front of me is ........ Edit Windows boot options for: Windows 7 Path: \Windows\system 32\winload.exe Partition: 3 Hard disk: 8b516ee6 [ /NOEXECUTE=OPTIN Can someone please help. I dont know what this means or what I'm supposed to do with it. Many Thanks
Step 1
Open the Windows Start menu by clicking on the icon in the lower left corner of your desktop.
Step 2
Click "All Programs," then the "Acer" folder.
Step 3
Select "Acer eRecovery Management" to open the utility. If a Windows prompt asks for permission to run the program, click "Yes."
Step 4
Click the "Restore" button in the pane on the left side of the program window.
Step 5
Click "Completely Restore System to Factory Defaults."
Step 6
Select the "Yes" option in the dialog box that asks you to confirm the action, and click "Start."
Step 7
Click "OK" in the second confirmation dialog box to restart the computer.
Step 8
Click "Next" in the warning window that appears after the computer reboots. This confirms that you realize restoring the computer deletes any data stored on your hard drive.
Step 9
Click "Next" again in the Restore Destination window, and click "OK" in the popup that gives you one last warning about deleting your data. The restoration process will begin.
Step 10
Click "OK" when the utility lets you know that the restoration is complete. The computer will restart, and Windows will finish the recovery process.
Click Programs
Click Acer Recovery Management
Click the Restore button on the bottom of the dialog box that opens
Click Restore System to Factory Default
Click Yes in the warning dialog box which asks if you wish to continue the recovery process
Click yes Start to restore the computer to the default factory settings
Sometimes there is a default acer password which is quite often 000000 that is 6 zero's
or place the recovery disk into your cd
restart the laptop pressing F12 i believe
then follow on screen instructions
many thanks
please let us know if this has helped you so that we can hopefully help others
Consider what data you still need from your Acer Aspire One's hard drive. Save the files to an external USB device.
Restart the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
Press the "Alt" and "F10" keys at the same time to bring up the recovery menu. Press "Enter."
Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
Connect the external USB device to your Acer Aspire One and transfer the data you saved earlier back to the netbook.
