I have a Maytag Ensignia washer that will not fill the basin with water during the initial phase of the wash. The water just continuously runs and empties.
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "That was definitely the case - I measured the drain pipe and it was just over 30 inches high. However, the hose was pushed all of the way down. I pulled it back up and tested it out and it works perfectly. THANK YOU, JW!"
SOURCE: Have a Maytag Ensignia top load, Washer basket is
sounds like your balancing ring or your springs gave out underneath to balance load
SOURCE: The water continues to run into my Maytag Ensignia
If it fills with water and starts the cycle and
the water keeps running in then your water inlet valve on the back where the
water supply comes in is sticking. It needs replacing.
SOURCE: My Maytag Ensignia top load washer continues to
Spraying some water onto the clothes while spinning is normal to help keep the clothes from wrinkling
