20 Most Recent
Maytag Ensignia MAV2757AWW Top Load Washer Questions & Answers
I have a Maytag Ensignia
Snubber ring that tub and spin basket assembly sits in is most likely worn. Very inexpensive part but extensive labor involved. I would suggest calling a competent service tech.
When i close lid it just makes humming noise and
If washer hums but doesn't fill, water isn't getting to washer check screens where fill hoses connect to washer. Screens may be blocked. If washer fills then hums check to make sure belt is on. Tip machine up to view belt underneath.
Washer will work in Rinse or Spin settings, but not any wash settings
If you are doing the normal procedures and the water elimination function is working, you have power to the circuit board and controls. The circuit board wash cycle section is independent and aligned with the timer circuit, thus the Wash Cycle Controller has failed. All of the functions or options are one the one board and a replacement board needs to be purchased and installed.
