To cancel call divert on your Panasonic Kx-TG6821AL phone, you will need to disable the call forwarding feature. Here's how you can do it:
Press the "Menu" button on your phone.
Use the arrow keys to navigate to the "Phone Settings" menu and press "OK."
Navigate to the "Call Forwarding" menu and press "OK."
Select "All Calls" from the list of forwarding options and press "OK."
Select "Off" from the list of forwarding options and press "OK."
This should disable the call forwarding feature and allow calls to be received on your Panasonic phone again. If you continue to have issues, you may want to try restarting your phone or contacting your service provider for further assistance.
I hope this helps! Let me know if you have any questions or if you need further assistance.
Assuming your telephone service provider offers the call forwarding service, yes. The procedure varies from company to company, but often you dial *72 from the landline, then the number to which you want the calls forwarded. That phone will then ring, and you must answer the call to confirm. To cancel the call forwarding, dial *73 from the landline.
If this doesn't work, contact your telephone service provider for their instructions regarding call forwarding.
What you want to do is to activate the call forwarding feature offered by your phone company. Different phone companies have different procedures. With many companies you dial *72 then at the second dial tone dial the number to forward to. This number has to answer the call to activate call forwarding.For precise instructions please contact your telephone company.
Call forwarding as you're describing is a service offered by your phone service provider, not a function of the phone. If your phone service package doesn't include call forwarding, you'll need to contact them to see about getting it. If you do already have the service, they will be able to tell you how to activate it and enter the number you want calls forwarded to.
All you can do from the phone itself is set up an outgoing message to inform your callers that you are away, and give the number they should call to reach you. You can also call your phone while away and check your messages, but it's a hassle. Call forwarding, especially if it's to your mobile, is definitely better.
Press
Dial 50(forwarding program number) on the keypad
Press or
Dial one of the following single digits for the condition you want
0-off
1-DND(Do Not Disturb)
2-All calls forwarded
3-Busy calls forwarded
4-No answer calls forwarded
5-Busy/No answer calls forwarded
Dial the voicemail access code(default is usually 500; this is the number that will ring voicemail)
Press or
Lift handset or press to end
you will need to dial *7102 9 phone number # this will forward all your calls
external call forwarding needs to be enabled on your system and you really need ISDN lines
To forward calls ringing a group of phones - from a phone within the group dial *7141 +group number - 9+phone number # to cancel this dial *7141 +group number
Forward to what? In a TA system call forwarding is 711 for all calls, 712 for Busy/No Answer and 713 for external calls, in the form of 71(1/2) ext and # or 713 (access code, 9 or 8x) number and #. External call forwarding has to be enabled in Class of Service for it to work.
Call forwarding is a feature from the phone company. Depending on the phone company it's usually 72# or *72 plus the number you're forwarding to. 73# or *73 cancels it. Check with your phone service provider for the specific codes for your service.
