SOURCE: upright freezer problems
Hi Robert,
Happy to help.
Sounds like it is low on freon
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
SOURCE: Frigidaire Freezer is not getting cold LFFU1765DW9
try to vacum the coils on back, if thats the problem u will feel them get a little warm if this doesnt work try to tap the relay next to your compressor, i had this same problem
SOURCE: Frost buildup around the inside top of the door of
This happens when your thermistor gets frozen along with the coils or there is a clogging of the freezer drain which causes Ice to build up and spread to the system. Another issue is that your thermistor may be faulty, telling the system inaccurate temperature. Incorrect freon pressure can also be a cause. I would advise first to have the ice melted by letting the unit stay unplugged and have it cleaned while at it.
SOURCE: I have a Frigidaire upright freezer model#
I have had the same problem with my frigidaire/electrolux upright freezer... I am researching to see if there is a pattern. Once or twice a year for the past few years, the freezer defrosted itself. I found the outside of the unit to be VERY hot to the touch around the time that this occurred.
We typically unplug it for a chunk of time when this happens and then replug it. It has always begun working again.
Sadly, we have lost many groceries and have had to clean many bloody meat messes as a result of this. ANYONE buying this freezer should save their receipt... That way, they can return it or have it repaired when it fails. I hate to think of sending all of these failing monstrosities to the landfill... =(
SOURCE: frigidaire upright frostfree freezer keeps icing
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
