20 Most Recent Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F Questions & Answers
You might be well served with a general defrost of the unit. But before you do, make sure that the mounting screws on the ice maker are fully in. Then if so, warm the lower surface of the ice maker where cubes are ejected with a hair dryer for a minute or two (medium not high). It could be that extraneous ice is catching the cubes. What does it feel like to the hand?
Frigidaire 20.3... | Answered on Mar 02, 2018
Sounds like a thermostat not making the circuit after a few cycles
Frigidaire 20.3... | Answered on Oct 23, 2017
Good Morning Friend,
I understand you want to know how to install a new door gasket on your Frigidaire freezer, model# LFFH21F7HWA. Typically this is not a do it yourself repair, as there are no step by step instruction manuals that will tell you how to do this. I suggest either contacting the manufacturer or your local authorized technician for further assistance. The technician has been trained on your specific appliance, and should be able to replace the new gasket with ease. Hope this is helpful.
-Best Regards-
WP
Frigidaire 20.3... | Answered on Jun 03, 2014
Your freezer seals on door are bad causing it to ice up and the light is telling you to defrost,these models have a design flaw that causes this,seals around door have to be replaced to fix.Call your local appliance company and see if they can order you some new seals.
Frigidaire 20.3... | Answered on Oct 27, 2012
Unplug it for about 30 minutes and plug back in and see if this does it.
Frigidaire 20.3... | Answered on Sep 11, 2012
Clean the unit entirely, coils, filter, etc. Then retry. You might have a faulty control board since it has not been used in many years. All depends on the location and humidity. That can tear up a thermostat and control board.
Frigidaire 20.3... | Answered on Jul 30, 2012
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Frigidaire 20.3... | Answered on Jul 05, 2011
You are absolutely correct. The compressor is leaking its Freon.----------- What is Freon? The Freon is a cooling refrigerant in the compressor.Its like a gas.The unit starts cooling with the refrigerant in the compressor.------- There is a leak in the compressor and that's causing the refrigerant to leak.You will need to get your compressor replaced.In some cases the leak can be sealed by a silicon sealant and required refrigerant can be again charged in compressor.---------- This job has to be done by special licensed tools.The HVAC repair techs have all this tools.They will first detect the leak , if the leak is major get the compressor replaced.But if leak is very minor then the leak has to be sealed by the sealant.The HVAC techs have this sealant with them.After the leak is sealed the pressure in the compressor is checked by the pressure tool.As per the pressure, additional refrigerant will again be added to the compressor and you can use the same compressor.--------- But as per me, if you get compressor replaced, then it will give exact required cooling. ---------- To get new compressor for you Frigidaire upright freezer, please click the link below:--- http://technoanswers.blogspot.com/2011/06/frigidaire-upright-freezer-glfu2067fw4.html ------------ This should help.Thanks.Helpmech.
Frigidaire 20.3... | Answered on Jun 12, 2011
Clicking means a compressor trying to start. You'll probably need a compressor start relay or a compressor.
Freezer repair in Corona Del Mar, CA
Appliance repair in Corona Del Mar and Orange County, CA
Frigidaire 20.3... | Answered on Jan 27, 2011
If the temp inside the freezer is 0 deg.F or -18 C then there is nothing to worry about
Frigidaire 20.3... | Answered on Oct 16, 2010
Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F Logo
51 questions posted
Top Frigidaire Freezers Experts
John Tripp
John Tripp
Dennis Boxerman
Bruce Denton
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
upright freezer frigidaire model
  • Freezers
