Im repairing thise amplify power comes but the faulty light is still on instead of swithiching off itself and secondary the out put relay is not swithing. we can see that the positive voltage that is 15 volts comes to the relay but the negative doesnt comes and i could see that 2N5401 and 2N5551 transistor, thise transisitor i could see that the negative voltage passes through it before it switch to the relay for working but it comes one pin of the transistor and doesnt cross
SOURCE: Audio Amplifier JVC Model A-GX3
If the service manual is not available on the JVC websites then you should just Google search "JVC A-GX3 service manual" There are many websites that archive manuals. You'll probably have to pay for a copy. Why can't you disassemble the unit and see the output transistor numbers first? More importantly how do you know this is the fault?
SOURCE: Power LED blinking - no sound
Check windings on input and output of main power transformer.
Make shure no open windings.
Good Luck
Big Red
SOURCE: RCA..PTV..P60924..CTC195M..NO START UP.
High failure parts = Flyback.....# 239111 and HO transistor =
237470 ....DO NOT USE cheap generic.................T.
replace both at same time......................T.
