20 Most Recent
Crown Xti-1000 Amplifier Questions & Answers
Crown XTI 1000 wont turn on
It will be the boost cap near the power switch. 220if 35v. In fact 3 caps die which kill XTi and CDi series. Amps. 2 x 220ugf and one 470 uf. All. Located yon the freuont right edge of the main PCB.
An actual crown tech
Tengo un ampificador crown xti 1000 pero el
RESPUESTA : Utilisa el Software que biene para Controlar el Amplificador con el PC o Laptop (BAND MANAGER) si no lo tiene lo baja por Iinternet. lo Instalar luego lo Abre y Busca EDIT se abre una ventana y en la parte de Abajo Dale clis a ...(RESTORE DEFAULT VALUES) Lo que esta haciendo es reiniciar el equipo, todo vuelme al estado original de fabrica.......
Power Crown XTi 6000 activates protection and does not generate PWM what could it be?
The Power Crown XTi 6000 is a power amplifier, and it sounds like it is activating its protection circuit and not generating a Pulse Width Modulation (PWM) signal. There could be a few different reasons for this behavior. Some possible causes include:
- Overheating: The amplifier could be overheating, causing the protection circuit to activate in order to prevent damage.
- Short circuit: There could be a short circuit in the amplifier, causing the protection circuit to activate.
- Input signal issue: The input signal to the amplifier could be causing the protection circuit to activate. This could be due to a problem with the source, such as a malfunctioning mixer or a disconnected cable.
- Output impedance or load mismatch: The amplifier may have a mismatch in output impedance or the load impedance which can cause the protection circuit to activate.
- Firmware or software issue : There could be a problem with the firmware or software that controls the amplifier, causing the protection circuit to activate.
Without more information, it's difficult to say for certain what the problem is. It's recommended to check the manual for troubleshooting steps and also check for any possible firmware updates. If problem persist it's recommended to take professional help.
Crown CDi 1000 amp thermal on
Google should have a manual for your 1000 amp thermal and also try on the companies official website too for a manual. Try searching on YouTube as well and YouTube should have videos about amp thermal on - Crown Audio Players & Recorders
Did you receive my DVD of THe Crown Series one?
Hello, Sylvia -
I have no idea what entity you meant to receive your question.
You posted in the Fixya.com website, which is intended for asking and answering questions on how to go about REPAIRING THINGS. Plus, your question landed in the Fixya category for Crown (brand) Audio Players & Recorders.
Perhaps you meant to message Netflix, or your local public library, or a person from whom you borrowed the DVD, or someone to whom you sold the DVD, or . . .
Best wishes.
