Our Belling Fridge Freezer appears good with the light on but only the freezer section appears cold.
The temp display show H for the Fridge and -18 for the freezer. What is the best way to check if this is caused by a failed part or is it possible that the appliance just needs to be defosted?
Many Thanks for any advice on this one!
SOURCE: Our Belling Fridge Freezer appears good with the
check for frost on the rear wall of the freezer,if so remove this panel,the evaporator coil is here,if its covered with ice use a hand held hair dryer to defrost it and then check the defrost heater under the coil for continuity,they go open(bad) if its o.k. then suspect the defrost control be it timer or adaptive board
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
