I am trying to put in fractions in my calculator but it wont allow me to. I hit the fraction button and it gives me a little L shape i read the manual and tried to change the format from linear to math because the manual shows that the L shape is because its in linear mode and i tried to follow the steps to change it but it wont change into math mode
SOURCE: I have a Casio fx-300es calculator. It displays
I guess you are not interested in knowing that you can switch from one form of display to the other by simply pressing the [S<->D] key, but I had to say it.
If you do not want to be bothered but the sight of fractions and radicals anymore, press [SHIFT][MODE][2:LineIO].
However, in this LineIO mode you lose the nice features that distinguish the Natural Display calculators from the old generation. And pressing [S<->D] will not switch between exact (fractions, radicals) and decimal displays.
Your choice.
Hope it helps.
SOURCE: problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
SOURCE: how to change or put math mode without fractions
I am not sure what you want because the mathIO mode IS THE ONE THAT DISPLAYS results as fractions.
You have two display modes: MthIO (with fractions, radicals) and LineIO (with decimals). Which one do you want?
To set MthIO press [Shift][MODE][1:MthIO]
To set LineIO, press [SHIFT][MODE][2:LineIO]
Concerning the scientific display mode.
Decimal numbers can be displayed in various formats, Fixed,Scientific, and Normal. If you do not want scientific display of results, just set the mode to Fix(ed) and specify the number of decimal digits. However if a number to be displayed (a result) is too small or too large IT WILL BE DISPLAYED in scientific format regardless of the mode you selected.
Press SHIFT MATH 2 to switch to the LineIO mode. You won't see fractions then. However, if magnitude of the number is too large or too small, the calculator will switch to scientific notation in order to fit into the display.
SOURCE: my fx-300ES calculator keeps giving
To convert a single result to decimal, press S--D. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
