SOURCE: Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
SOURCE: n80sb-1 stanley bostitch framing gun.
Yes your nailer will drive other sizes of nails. For info and parts go to www.bostitch.com and look for the support tab then select service parts. Here you will find parts list and manual. To remove the tva11 trigger valve remove the retainer pin (the pin is 3mm) for the trigger and remove trigger. Next remove roll pin/pins that retain trigger valve. Use heavy glove to catch trigger valve as you apply air pressure to gun. The valve could pop out with great force so try lowering the pressure to gun. Before installing the new valve, check the opening for sharp edges which will cut orings. Good Luck and email if you have more questions.
SOURCE: air coming out the trigger of a stanley air gun
Go to the Stanley Bostitch website. Click on schematics & parts. Find your model number in the drop down list. There is a list of parts and pricing. Just above the parts is a link for the schematic. Honestly, I worked on these things for years. It is best to replace the entire trigger valve. It comes as a kit with instructions grease, and a little tool to hammer your pins out. Lemme know if this helps. Please rate me
SOURCE: I have a N60FN Bostitch nailer. It's loosing air
Your nailer uses a trigger valve part # tva6 (or tva1, but use tva6) (cost about $20) and is sold at www.bostitch.com or ebay for generic. If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body (Use punch for 3mm hole). Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. Note the two grooves on the side of the valve where retainer roll pins hold valve. Remember to insert the valve with these two groves aligned with path of roll pins. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring/seal on plunger is cause of leak. Try using an oring with smaller inside diameter than the broken or loose fintting seal that is present. It must fit pretty tight and be slightly thicker than 1/16" to work. Remove the outer orings to valve and clean and re-use same. Clean the valve port in body of gun and check for sharp edges to prevent cutting orings before inserting the valve. Use silicone lube or oring lube on the orings and the valve port (Danco silicone paste sold at Lowes in the plumbing department). Good Luck on your repair and email if you have other questions
SOURCE: I have a bostitch ridge runner that leaks air
The air leak can be one of a few things. FIrst make sure that you have added some pneumatic oil to the air stream. This will lubricate the o-rings and make a tight seal. If that fails to resolve it, repalce the o-rings. (kits available for around $20). Next, woul dbe the trigger assembly itself. These triggers wear over time and are easily replaced.
See the website below for parts and a good diagram of the construction of the gun. You should be able to replace the parts by following the diagrams.
http://www.ereplacementparts.com/bostitch-parts-c-29443.html?gclid=CO6tkb2y6KICFciA5QodOlL9xg
Please note that the exactmodel number is required to get hte correct diagram.
Hope this helps,
Dan
