20 Most Recent
Stanley Bostitch Coil Framing Nailer Questions & Answers
Fires first nail will not fire second nail
Ez test. With nails removed, and door open driver should be at top of cylinder. If driver is down replace piston oring. If driver is up, lightly strike nose of gun against softwood. The driver should stay at top. If driver drops with light tap replace piston oring. If driver stays at top dry fire the nailer against softwood. The driver should hit the softwood leaving a mark and return to top. If driver stays down or does not travel all the way up pull the cylinder and make sure checkband is installed. Checkband is oring or rubber band covering series of holes on lower part of cylinder. Good luck
Bostitch n80 does not feed nails
make sure that the feeder spring is not broken this stops nails or can jam them or cause them to skip. Some nail gun types work bette if you buy their brand of nails, but it could possibly just be dirty or maybe check the nail size. You should also have a way to adjust how far your nails are in the bucket where you put your nails, it should go up or down by spining it.
N88 bostitch nailer fires when connecting air hose
I have seen this on dewalt nailers also, caused by trigger valve worn. on Bostitch nailer part # tva6 remove roll pins retaining trigger and trigger valve. one roll pin for trigger and one or two for valve. With pins removed apply air pressure to gun popping out the valve. Use glove or folded-up shop rag to catch the valve as I pops out. Be sure to reduce air pressure as it could come out with force. Good luck
My framing Bostitch air gun , model N95RHN blows
prolly clogged, buy a rebuild kit and use it making sure all parts are totally clean before reassembly. in the future be sure to drain your compressor at least daily after use (more on wet or humid days) to avoid this
How do i rebuild a 1979 gm Rochester carburetor ?
Try to locate a "rebuild kit" from a parts store or online. When you locate one, ask if it includes the complete instructions to install the kit. I have rebuilt several dozen, and kits have an instruction sheet.
Be blessed.
Dewalt D51822 trigger goes 1/2 way without
Dewalt nailers use some orings that are made of vinyl (clear to yellow in color instead of buna or viton). These orings fail by getting soft and sticky. The gun may not leak but will not work correctly. The trigger should fire the gun when depressed about 1/2 way in. The oring repair kit has the same orings. I use generic orings in the gun to solve the problem. There are two orings inside the gun that should be changed and at least two on the trigger valve stem. In time the gun may fire a nail when you connect the hose. Check the internet for recall on some of these guns. The orings in the gun that should be replace make contact between the white cylinder spacer and the cylinder (smaller is standard oring # 141 the larger is 74.4mm x 3.1mm). The two rings on the trigger stem are 2mm x 1.5mm . If you do not have a source for orings then just replace the trigger valve. You also might try setting the depth adjustment all the way down. Good luck.
