20 Most Recent
Stanley Bostitch Nail Gun Questions & Answers
The driver on my Stanley 18 ga. finish nailer( SB-
Remove the 4 screws and pull cap off .careful not to rip the gasket and pay attention to how the head valve sits. Pull driver out to make sure its not bent . If its fine put driver back in place. Remove the head valve from cap . Replace the oring around the head valve part # 180535 . If thats not a option take a thin strip of teflon tape and wrap in around head valve once then put old oring over it. Grease or oil , put cap back on and test fire. Should be good to go . Best of luck !
How do i control the depth the nail shoots in a bostitch coil nailer
The bostitch nailer pictured along along with your question is a RN46 roofing coil nailer. It has a dial on the front of the nose for adjusting depth. Some older nailers (roofing nailers) do no have a means of adjusting so were set at the factory for best performance. The question of depth usually comes up when lower bumper fails and the nail is driven too deep. Easy test. Remove nails and find a very soft piece of wood. Dry fire the gun against soft wood and measure how deep the driver is entering the wood. Harder test. Remove the head and use any handy tool to push driver down to bottom. Measure how far the driver extends past nose (should be about 1/8 to 3/16). If more, replace the lower bumper. Good luck
Manuals
on my Maxim there is a lever up front that opens the forward part of the head. It isn't totally obvious if u don't know it is there
Nails skipping
Usually caused by debris in the small air passage from inside of gun to feeder piston. Easy to check. Remove the head and pull out the cylinder. Debris in the chamber is usually small pieces of oring or the lower bumper is coming apart. This debris will enter passage to feeder which is visible at bottom of chamber. If debris is found, clean chamber, passage, and feeder chamber. Debris will lodge on the oring between the body and nose. Clean and replace parts as needed. If the gun was found to be clean inside, suspect weak or missing feeder spring/s. Good luck/
Hi air is leaking from the top of the gun thanks
If you have a very slow leak most likely the lower half of the headvalve (white plastic) is scratched. The gun will work ok but waste air. Parts are not expensive and are available from Dewalt service center. Remove head and pull out headvalve. Look for scratches where oring makes contact. If a lot of air is leaking, most likely cylinder seal needs replacing (vinyl ring installed on the headvalve) or has debris keeping it from making full contact with the cylinder. If you have lots of hours of use you may consider installing the rebuild kit. Good luck.
