You did not clear that the printer is connected in wireless or Usb. However, below are the steps for both.
USB.
Please click on Start on the computer----Control Panel----Printers or Printers and Faxes or Devices and Printers.
Please right click on C6180 printer icon and click on use printer on line.
This will fix the issue, still persists, follow the below steps.
Click on Start- and in the search box type "services.msc" and hit enter.
Here, do we see an option print spooler?
Just stop that print spooler
and then restart that spooler.
WIRELESS.
Press the Setup button (
) on the front of the printer.
Press the Down Arrow button (
) to highlight
Network , and then press
OK .
) to highlight
View Network Settings , and then press
OK .
) to highlight
Print Network Configuration Page , and then press
OK .
Please note down the ip address of the printer and then follow the below steps.
Right-click on the printer Photosmart C6180 series---- click " Properties" , and then click the Ports tab
Click Add Port .
Click TCP/IP port and put (ip address of the printer)
, and then click New Port . The Add Port wizard starts.
Click Next ,
Follow the on-screen instructions to finish adding the port.
Then try to print and the issue will be fixed.
this isuue occurs because of the power failure or thunder storms or if we turn the router OFF.
I would suggest you to never turn off the router.
If, however, you face the same issue with the printer, please follow the same steps and the issue will be fixed.
Thanks Swan, this sounds like it might help, but could you possibly expand? I've looked through the printer options but not sure what I'm looking for! Dave.
Hi Swan. Unfortunately I don't have Image Enhancement in my print setup - probably a Vista thing (nothing new there). Thanks for trying though.
Dave
