On the inside of the boot ... Under the plastic cover.. There is a hole .. About 6 inches long ans 2 niches high.. Looks like it is a access hole for the wiring.. But the water comes in there... The outside of the same spot is where the boot lid comes down with a rubber bit into a hole ...
That's the air vent. If you look carefully water should be coming from the plastic frame that holds the vent with rubber flap. Just make the frame leakproof with mseal or some other compound. Question was asked 2 years before but might be helpful for others. I had the same problem and this how I fixed it.
SOURCE: high fuel consumption on Suzuki swift 2003.
hi
im dave
Is there a leak in one of the fuel lines? Check the length of the fuel lines from the pump (you may need an extendable mirror to see the top of gas tank) right up to the point where it enters the fuel rail on the engine. Take special note of the junctions and try to do it with the car running and at a slight idle so fuel is pumping. Check next for a smell of too much gasoline along the fuel rail as one of the injectors may be improperly seated and or broken and leaking. Has the service engine check engine light come on at all or come on and gone out. If your o2 sensor(s) go you use more fuel. If they go there should be a code stored in your PCM (computer). You can pull any codes out of that car by finding the connector and jumping it. Also if your air element(filter) or any pipes are clogged in that system up to the throttle body you will use much more fuel.
Let me know how these tests go
SOURCE: 96 suzuki vitara - radiator empties but no visible leak
Check the passanger side floor board for moisture this could indicate a bad heater core. Then I would check the engine oil and make sure its not milky looking (head gasket). make sure when you fill it let it run with the cap open with you looking into the cap to be sure is circulating and not vapor locked (air pocket)
hope this helps
SOURCE: water leaking into footwell drivers side of suzuki
Yes, the plastic caps at the bottom of the footwell, are for drainage. (Don't forget to replace them. You may not be pleased with yourself, if you don't, on a real rainy day!)
Does the water have a real nasty smell, and the inner windshield has a film on the inside? If so, then you have a heater core leak, and it's antifreeze.
If not, your air conditioning drain duct is plugged, and needs to be cleaned out. I also suggest a real weak solution of bleach and water, to be applied in this area, to kill any mildew that might form. (Unless you are allergic to bleach. If so, you may want to try an alternative. Mildew is bad for your respiratory system)
SOURCE: i bought a brand new 2007 suzuki swift,it has only.2007 SWIFT
i would say its wear and tear,you can kill a clutch in a day if your hard on it,,,or it could take 150,000 miles,,suzuki will classify that as a wear and tear item,,they are really tight with that stuff,
I am notĀ sure what the question is here, please clarify. ThanksĀ
