I have just bought a go gear vibe mp4 and are having trouble adding podcasts and other mp3 files. When I add them, they become a part of the music list, and this is annoying when playing random tracks from the mp4. How do you isolate them so that you can listen to them when you want, without them being part of the list of songs?
If the device offers the ability to create folders (like rock, folk, classical) that are selectable, create one called podcasts. If not, retitle all the podcasts so that the file names all start with a Z, and then at least they will be at the bottom of a master list when played in sequence. Doesn't help in shuffle mode though, as the podcasts will still play randomly if you can't isolate them to a separate folder.
SOURCE: Phillips Mp3 player-Songs get cut-off half-way through playing
Play this file in media player 9,10.if it play fine then the problem of mp3
SOURCE: loaded music in mp3 thru windows media but still in shuffle mode
try formating the mp3 player and then get the new frimware for it and the putting the songs back on there were did you get the song from
SOURCE: i added new songs to my phillips go gear...now
Is there only certain music or all of them? Maybe it can't read the format of the music.
SOURCE: whenever i try to play
"File format not supported" means that the song that you've downloaded into your MP3 player is NOT an .MP3 file format. For each MP3 player have their own supported file formats. You need to check the manual of your MP3 player to see what are the supported sound file formats (i.e. .mp3, .wma, .mp4). Then check the file format of the songs that are saved in your player.
If the songs are supported but you're still getting the error message, try to delete all the songs and then download the songs again and save it into your player. If the same problem occur, then it may need a firmware upgrade or reformat.
Thank you and good luck!
Testimonial: "thanks"
SOURCE: It says on the phillips
yes your correct there are different types /size of mp4 s here is a video on Philips site that explains what sizes format are acceptable usually the player comes with a disc that has a free tool to convert videos to proper sizes hope this helps and please vote
