Panasonic PT-47WX49 47" Rear Projection Television Logo
Posted on Nov 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stk394-160 Convergence IC, number on top right of chip
I am planning to fix a Hitachi Ultravision convergence problem by replacing the convergence chips. I got the Hitachi kit and it came with two STK394-160 convergence chips. Each chip has a code in the top right corner of the chip. One code is D7G22 and the other is D7115. I am guessing the chips function the same and I can put either one in either location, but want to make sure the code is irrelevant to which location the chip goes. Can I put either chip in for either chip currently on the board? The chips on the board are both stk392-110 chips. The kit came with six resistors to replace for the chip upgrade which I plan to do. Hopefully it will go well if I put the chips in either location.
Thanks, I have the panasonic ptv47 projection set and ordered the sanyo stk394-160 replacement ic's. After soldering both new ic's to board and turning set on, i see smoke and the set turns itself off. Checked solder joints to ic's to make sure their not touching and as far as i can see they are not. Is there anything else that could cause the smoke? The lamps do not turn at all by the way. Could I have fried something on the board when I desoldered the original ic's? Help!
  • Qwilson Feb 02, 2009
    I have a Panasonic PT-47WX49e which is experincing the convergance issue with the wavy red line at the lower left part of the screen. I have elected to repair the issue myself. My question is this can you upgrade the STK394-010 to a higher Convergence IC like a 150 or higher also should the resistors be replaced as well or just the convergence IC?
    Thanks,
    Q.
    [email protected]
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2978
Points
I have read both of the above posts.
On the first post, the 'codes' are the date codes. Both parts were manufactured in 2007, and will have no bearing on performance, should both lots not be the same as they were manufactured on different weeks.
On the second post:
There is allot of misinformation on the web pertaining to the applications of STK394-160(E)'s.
This special device was manufactured by Sanyo exclusively for Hitachi PTV's. They will not work in any other projection TV's except for Hitachi. Let me say this again, "They will not work in any other projection TV's except for Hitachi." The 'E' suffix is the nomenclature for PB Free or lead free. All STK394-160's were manufactured as 'lead free'. The 'E' will not appear on the part. Here's more information:
For Hitachi PTV's ( Projection TV's ), STK392-150 replaces STK392-110. STK392-120 should be replaced with STK392-120 or STK394-160's in matched pairs. The -120's are 4 amp devices while both the -110's and -150's are 3 amp. We market replacement kits for -110's that contain two original Sanyo STK392-150's and the associated resistors along with solder and resistor designations for all models. We also have an STK394-160 Kit, along with solder and resistor designations for all models.
Prelco electronics is a direct purchaser of STK's IC's directly from Sanyo Semiconductor Distribution. If you would like the real parts, your search has ended. Parts can be ordered on line, or toll free: 888-773-5268, ( 908-429-9999 local ) Sales X 2, http://www.prelcoparts.com
Feel free to contact us via email: [email protected]
  • Anonymous Jan 26, 2009
    The STK392-180's were made for Pioneer to replace STK392-110's. They are not to be used in place of STK394-160's as both the STK392-110'a and the STK392-180's are both three amp, while the STK394-160E's are used to replace both 3 amp and 4 amp devices in HItachi PTV. Will they work as a test ?... yes. But I would not leave them in for the long-term.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 13, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2857
Points
I know there are a lot of questions on what TVs a STK394-160 will work in place of a STK392-110. I just wanted others to know that they may be OK in Panasonic TVs. I put a pair of them (genuine Sanyo STK394-160 from Hitachi x480293 kit purchased from Encompass). 3 years later they are still running fine. My TV is a Panasonic PT-53TWD63G, chassis BP830, MFG 10/03.
Anonymous
Level 1:
New Friend:
  • Posted on Dec 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2857
Points
I have changed 392-110 thrice! in 5 yrs. which ic's supersede these?
my rptv is phillips 46".
pl help!
Anonymous
Level 3:
  • Panasonic Master 5,138 Answers
  • Posted on Nov 29, 2008
Anonymous
Panasonic Master
Level 3:
Answers
5138
Questions
5
Helped
1004533
Points
13534
Heres your first BIG mistake you have put wrong STKs in Use Stk392-180s or replace with 110s I always upgrade to 180s they hold upbetter Stk 394-160s does not work in this set if ics where 110s then use 110s or 180s
Anonymous
Level 1:
  • Posted on Mar 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2857
Points
The STK394-160 WILL work in other than Hitachi!! I just put a set in my Mitsubishi.. The convergence was never that easy to adjust!!
1helpful
My hitachi 60"ultravision tv has a double image at the top in blue and yellow. the magic focus has no impact. any ideas?
Pretty common failure with rear projection CRT sets.
Sounds like one of your convergence amp chips have gone out.
You can buy the chips from several vendors, or kits.
Do a search with your model number and "convergence amp chips". Shop around for the chips as they seem to be getting cheaper as this type of TV isn't as popular as they once were.
I've picked up several used Sony and Mitsubishi sets for nearly free that had this problem..
I have a Hitachi 60sdx88ba UltraVision Digital Projection TV @ the top of the screen a yellow swoosh 6 inches wide with a blue line 8 inches under it. On the right bottam a 3 appears. Double image on the...
You have a defect in the convergence circuit. Both chips will need replaced and possibly a resistor or two. Chip part numbers are STK392-110. Typical repair runs around $350
Bill W
integrityhomeworx.com
Hitachi 46f500 46 in problem double picture end two collor
This is symptom of convergence output chips failure in rear projection tv, replacement of convergence output chips will fix the problem.
Chips/ IC replacement requires soldering work in circuit board, if you are not familiar with electronics stuff fixing an soldering work, call local tv repairman to help you.
Thanks.
3helpful
2answers
Blue shadow
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
2answers
Picture has 3d effect.
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
3helpful
2answers
When doing Magic Focus on Hitachi 51SWX20B I get Error 3, and the Process Stops. I have a Hitachi 60SDX88BA that also has a blue semi circle at the top of the screen. I have run magic focus and it stops...
  • Screen looks 3D
0667c5f.pngSOLUTION
3helpful
2answers
My hitachi ultravision have double vision and corlor on top
  • Screen looks 3D
0667c5f.pngSOLUTION
1helpful
PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Hitachi Ultravision 50" projection Tv
This is an indication of convergence issues. There are two ic chips that control this and there is a likely hood of there failure and need to be replaced. there possible other issues with ouput resistors and fuses. At my shop the cost to replace these chips are 200 to 350. not a too difficult repair.
I Have a Hitachi Ultravision projetion TV Ned help to fix it.
This sounds like the solder joints on one of the convergence output IC's have cracked loose or the IC itself is defective and quitting when it warms up. The IC needs to be either resoldered or replaced.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
