I cant seem to get sound out of my Samsung HT-Z110 with it on AUX and i have the analogue RED & WHITE output from tv connected to the audio input on the Samsung
SOURCE: i cant get any tv audio on my samsung ht-z310.
Red and White cable wires are usually for Audio wires. Make sure yo connect it to either Audio (Red & White) Out or Aux Out in your TV and connect it to your Audio (Red & White) In or Aux In in your Sound System/ Home theater.
SOURCE: When i turn on my samsung HT-Z110, the word "Protect" appears...
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking
noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal
fault is the natural cause for protect mode. If all the above did not
work, then the problem is a blown component or an internal fault. In
this case the unit must be taken apart , tested and repaired by an
experienced person.
If the unit is less than one year old, or if you
want to get service, call Sony at the phone number listed on the
product documentation.
Regards.
SOURCE: when i switch on my samsung HT-Z110 the word hello
Audio receivers have an output protection circuit called "protect mode", this is to protect the receiver from short circuit failures.The speakers and speaker wires are what I inspect thoroughly first, look for bare speaker wires,or bare wires that are touching each other at that point,check speaker wires at the back of the receiver for sloppy connections,etc.If all looks good then try disconnecting all the speakers at the receiver,then turn power on to see if it goes into "protect mode", if it does the the receiver probably has an internal short and will need to be sent in for service,if it doesn't go into "protect mode" then connect one speaker at a time back into the receiver until it does go into "protect mode" then which ever speaker you connected last is the speaker that is shorted(blown) and then you know that speaker is the problem and it will need to be replaced or repaired. Good luck !
Testimonial: "well it matched your suggested solutions for my problem, i need to send my unit for service, thank you very much!"
SOURCE: samsung ht z110 says protect an then switches off
Audio amplifiers IC´s damaged need to be replaced
SOURCE: My Samsung HT-Z110 does not play any DVD's anymore...
check if the cds works if they work you need to replace the motor disc spindle
