On amazon you can find replacement parts to fix it. Amazon com Jobsmart Hope this was helpful. cheers
SOURCE: compressor will not build pressure
Have you tried adjusting the pressure regulator / also make sure that the over presser blow off is pushed in not popped/ do you hear air leaking ?
SOURCE: air compressor 3 gallon
I had mine do the same thing... The head gasket blew out between the intake & discharge side.
I went to O'rileys and bought the blue gasket paper and cut out a new one ($3.00) works fine now.
Just take off the plastic cover, undo the discharge line at the compressor head, remove 4 allen
head bolts, lift off cylinder head and you'll see the gasket gone at the center bridge.
Draw a picture of the way the valve plate under the head is assembled so it goes back together right.
Use care cleaning the old gasket off, NO power tools....Hand wire brush to preserve the little ridges
that bite into the gasket, Soak with solvent helps..You can also order the gasket kit from Sears
about $12.00...Hope this helps ya......John
SOURCE: coleman compressor no build up of pressure
your correct either the valves are worn or maybe just need cleaning as for the gaskets,idont know what part of the world your in but check out coleman on the internet or failing that ,i have maid these from gasket material suuplied from my local bearing supplier
SOURCE: 6 gallon proforce air compressor not building any pressure
You might have a broken valve. You'll need to pull the head apart. But make sure replacement parts are available first. Does this unit have an unloader valve on it ? That could also be your problem. You probably should check this first
