"memory full! please insert an SD memory card" but the SD is empty, i don't know working, the camera's internal memory is empty too, i need i solution practice and effective, thanks :)
SOURCE: Just put 2gb sd card
on a kodak you can also copy your internal photos to card-go to menu and find menu highlight that says storage or something like that and change setting to use card first-when the camera has a card in it it will usuallt default to card first
SOURCE: Camera does not read SD Memory Card
thank you so much this worked great it solved my problem thanks.
SOURCE: On my Kodak M863 digital
click review press menu go to copy click photo or all that should transfer photos to sd card .
SOURCE: finepix s700 says memory full and wont take more pictures with sd
i know this is late, but my camera had the same problem.
1. If you go in the setup menu.
2. Push the right button once and scroll down to the menu that says format.
3. It will ask you if you want to erase all data.
4. Select No and everything should be fine.
