My Malber worked fine until the faucet needed to be replaced. Now, the adapter doesnt fit onto the new faucet. I went to ace hardware who sold me a dishwasher hose snap on adapter - it seems to fit the faucet and the hose, however it leaks where the adapter is connected to the tap. any ideas?
SOURCE: Water Leaks from beneath my washing machine
Our WM2077CW just started the water leaking from underneath. We unplugged the electrical cord and disconnected the hoses (water, drain). We then removed the inspection plate from the back and checked for wet hoses. The big black hose on the bottom was a little wet. On careful examination we found a small hole that looked like a material fatigue failure at the point where the accordion part of the hose met with the solid part of the hose near the main drum connection. I suspect this is may occur in other LG washers of the same design. Unless your floor is perfectly level it's hard to tell whether coming from the left or right side really indicates where underneath the water is coming from.
SOURCE: water leaking from under the front of the washing machine
The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
SOURCE: washing machine leaks when not in use
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
SOURCE: kenmore washing machine series 90 is leaking
Hi MPT,
Don't take the back panel off!!!
Watch this video to learn how to access the machine.
Generally on a Whirlpool built Kenmore like yours, the drain pump has failed and now it's leaking. The pump is right there in front, the big round white thing. It's connected to the motor by 2 clips. It'll be one of two types of pump... this one or this one <----notice the difference in hose connections?
It's easy to replace, just make sure that the machine is completely empty when you remove the hose or have a shop-vac handy when you do.
And don't forget to rate my solution as "FixYa", deal?
SG
SOURCE: Washing machine leaking from bottom.
maytag pav2300 washer leaking at pump..should I replace entire pump or just seal? also, screeches to a stop....what is causing this?
