Just moved house no oven handbook,i cant work out what the symbols mean on the oven, they is differant squares with symbols in, symbol of fan then fan and 3 little tear drops then just 2 tear drops then one, then one solid line at top then solid line at bottom then solid line bottom and top. help thanks Hannah dont no the make the label has come off the front.
SOURCE: ZANUSSI ZDQ 595 BUILT IN ELECTRIC DOUBLE OVEN
have you reset the clock after the power outage?
this is necessary before oven will work
suspect you have it on auto in error
SOURCE: zanuisi top oven making noise
Yes , there is a cooling fan located at the top of the oven
It could be the fan blades catching, or a noisy fan bearing.
You would have to access it by removing the top oven cover to check., and yes it could be as a result of having it cleaned.
Plz rate my solution.
Thanks.
SOURCE: my oven wont get to temperature why?
If oven is getting hot , but not hot enough, then the thermostat is probably faulty.if no heat at all, then you need to replace the oven element.
Please rate my solution.
Thanks.
SOURCE: Zanussi ZDQ 595 fan oven not heating
You need to replace the round fan oven element located at the rear of the oven compartment behind a removeable cover where the fan is located.
Testimonial: "Thankyou - i did not know there was another element in there!! I cannot believe how expensive these ovens are considering the simplicity of their construction and low cost of the components inside.. Thanks again..!"
