SOURCE: operating system not found
Hi there.
Hard drives don't come with operating systems on them, you have to reinstall the OS yourself either with your recovery CD or an install disk.
Post back if you need anymore advice.
Good luck and thanks for using FixYa!!
SOURCE: get error message "operating system not found"
Run diagnostics on the harddrive. if possible reseat the Hard drive, i.e take it out and put it back again. and then try installing the OS. remember you have to boot from the laptop to install OS. Hope you are doing it correctly
SOURCE: Win Xp Drivers for sony vaio vgn-fw230j
Go to download the drivers that you require from the Sony WEB site, to their support/download page. Make sure you input your model laptop and select the Windows OS that matches your installed operating system.
Use this link :-
http://esupport.sony.com/perl/select-system.pl?DIRECTOR=DRIVER&SR=nav:service_support:electronics:drivers_software:esup&ref=http%3A//www.sony.com/index.php
SOURCE: I can't boot up the Vista install on a Sony Vaio VGN-NR160E
go to your BIOS Setup, see to it that there is a Hard Disk Boot Priority, maybe you didn't put it there.
SOURCE: Sony VAIO VGN-CR320E Motion eye camera never
Have a look in device manager
Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc
have a look under imaging systems click on the + sign and see if you have a Camera listed
Also on Sony they should have supplied an application for the camera
maybe called ArcSoft WebCam Companion - see if you have that program folder - listed at all
