SOURCE: The add water light stays on not matter how much water is in the reservoir
lot of time you have a magnet in the water tank fill it with water and gently tap the side of machine the magnet is block or jam on empty
THANKS FOR USING FIXYA
PIERRE
SOURCE: Need a replacement gasket for the water reservoir for Keurig B40
I would suggest you contact the company directly for advice on where to get that part or possibly they will be able to supply it to you directly.
Robert
SOURCE: Keurig b40 elite turns on, then off after a few
I had this problem and it got worse. I had to return the coffee maker to Keurig. They sent a refurbished one, which also had to be sent back. I am getting irritated with the poor quality.
SOURCE: My keurig stopped pumping water through to make
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
