I keep getting an error code ''paper jam in E remove paper''. When I open the drawer, there is not a paper jam. I suspect it may be one of the opto-interrupter modules. Any ideas?
Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
Exhaust blower motor error. Common problem for these older machines and quite a pain in the neck to replace. Not something that could be explained through this forum.
ls lt an image problem? image problem can be occurred if the solid black part of the image is on top. try to reverse the image by scanning it invert the image on the other side meaning the solid part be placed at the bottom.
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
1. Check that absolutely no paper is jammed within the infeed paper sensors. Sometimes a tiny piece of paper will get stuck in the sensor after a jammed sheet has been forcibly removed.
2. Use a can of Dust-Off or similar compressed air product to blow the paper path out. Paper lint can block a sensor.
C-3 code
