Canon PowerShot A560 Digital Camera Logo
Posted on Apr 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can see my pictures in the camera but i cannot see the picture if i connect it to my computer
Laurie Pullman
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 65 Answers
  • Posted on Apr 10, 2012
Laurie Pullman
Expert
Level 2:
New Friend:
Greenhorn:
Answers
65
Questions
0
Helped
26900
Points
140
Install the software from the CD that came with the camera (or download it from Canon's website), Plug the camera in using the USB cable and the computer should go through it's Found New Hardware routine.
What you do now depends on what software and operating system you have. The easiest is probably to install Picasa and use the import function.
1 Related Answer
  • 102366 Answers
  • Posted on Apr 13, 2011
SOURCE: how can i transfer pictures from Ixus 950 to
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Download pictures from camera to pc
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
tip
Transfer photos from Camera to PC
<span><span><i><b>Hello and welcome to FixYa!</b></i><br /> <br />To transfer your photos from your</span><span> Digital Camera</span><span><span> to PC, Follow the given steps:</span><br /> <span style="font-weight: bold;">1.</span>First connect your digital camera to your computer.<br />You can do this in two different ways:<br /> <br /></span></span> <ul> <li><span><span> <b>Use a USB cable:</b>Most digital cameras come with a cable that connects the camera to a USB (Universal Serial Bus) port on your computer.</span></span></li></ul> <ul> <li><span><span> <b>Through memory card:</b>A memory card reader is a piece of hardware that plugs right into your computer. You remove the memory card from your camera and insert it into your memory card reader, similar to the way you might transfer a file between two computers using a floppy disk.</span></span></li></ul><span><span> Now connect USB cabe or Memory card Reader to the port of the computer<br /> <span style="font-weight: bold;">2</span>.Once you've connected your camera to your computer or inserted your memory card into your memory card reader, your computer will detect the connection and ask you what you want to do with your pictures. If you connected your camera with a USB cable, click <b>Microsoft Scanner and Camera Wizard</b>, and then click <b>OK<br /><br /><img src="angel_bird_1.gif" /><br /><br /></b></span></span><span><span>If you are using a memory card reader, click <b>Copy pictures to a folder on my computer using Microsoft Scanner and Camera Wizard</b>, and then click <b>OK</b>.<br /><br /><img src="angel_bird_2.gif" /><br /><br /></span></span><span><span><span style="font-weight: bold;">3</span>.When the Scanner and Camera Wizard appears, click <b>Next</b>.<br /> <span style="font-weight: bold;">4.</span>All of the pictures on your camera (or in your camera's memory card) are now displayed on the Choose Pictures to Copy page. By default, Windows XP selects all of the pictures for downloading. If there are pictures you do not want to download, just clear the check box next to those pictures. At this stage, you can also rotate pictures that you took while holding your camera vertically. To rotate a picture, click it, and then click either the <b>Rotate clockwise </b>or <b>Rotate counterclockwise </b>button on the lower-left side of the page. When you have reviewed the pictures for downloading and rotated your vertical pictures, click <b>Next</b>.</span></span><br /><img src="angel_bird_3.gif" /><br /><br /><span><span><span style="font-weight: bold;">5.</span>On the Picture Name and Destination page, type a name for the group of pictures. (This name, plus a number to differentiate each picture, will be applied to each of the pictures you download; for example, if you name the group "Vacation," the pictures will be named "Vacation001," "Vacation002," and so on.) Click <b>Browse</b>, and select a folder in which to save your pictures.<br /> <span style="font-weight: bold;">6</span>.If you want to erase the images from your camera's memory card to make space for new ones, select the <b>Delete pictures from my device after copying them </b>check box, and then click <b>Next</b>. The Scanner and Camera Wizard copies the pictures from your camera to the folder you specified and then removes the pictures from your camera's memory card.<br /><br /><img src="angel_bird_4.gif" /><br /><br /><br /></span></span><span><span><span style="font-weight: bold;">7.</span>On the Other Options page, you can choose to publish your pictures to a Web site or order prints. If you have finished working with your pictures, click <b>Nothing</b>, and then click <b>Next</b>.<br /> <span style="font-weight: bold;">8.</span>On the final page of the wizard, click <b>Finish</b>. Windows XP opens a Windows Explorer window showing the pictures you downloaded from your camera. Your camera's memory card is now clean and ready to store new pictures. If you connected your camera to your computer using a USB cable, disconnect your camera. If you used a memory card reader, return the memory card to the camera.<br /> Your photos are now stored on your PC, ready for whatever you want to do with them, and <span style="font-style: italic;">your camera is ready to take more pictures.</span></span></span><br /><br /><span>Thank you for Using FixYa!</span><br /><span><span><br /></span></span>
on Apr 28, 2011 • Cameras
2answers
I dont know how to transfer my pictures from my sp-600uz into my pc. could you help me please? thanks
To upload your photos from your camera
Olympus SP600UZ Digital Camera to PC
1.First connect your digital camera to your computer.
Use a USB cable:Most digital cameras come with a cable that connects the camera to a USB (Universal Serial Bus) port on your computer.
Through memory card:A memory card reader is a piece of hardware that plugs right into your computer. You remove the memory card from your camera and insert it into your memory card reader, similar to the way you might transfer a file between two computers using a floppy disk.
2.Once you've connected your camera to your computer or inserted your memory card into your memory card reader, your computer will detect the connection and ask you what you want to do with your pictures. If you connected your camera with a USB cable, click Microsoft Scanner and Camera Wizard, and then click OK
If you are using a memory card reader, click Copy pictures to a folder on my computer using Microsoft Scanner and Camera Wizard, and then click OK.
3.When the Scanner and Camera Wizard appears, click Next.
4.All of the pictures on your camera (or in your camera's memory card) are now displayed on the Choose Pictures to Copy page. By default, Windows XP selects all of the pictures for downloading. If there are pictures you do not want to download, just clear the check box next to those pictures. At this stage, you can also rotate pictures that you took while holding your camera vertically. To rotate a picture, click it, and then click either the Rotate clockwise or Rotate counterclockwise button on the lower-left side of the page. When you have reviewed the pictures for downloading and rotated your vertical pictures, click Next.
5.On the Picture Name and Destination page, type a name for the group of pictures. (This name, plus a number to differentiate each picture, will be applied to each of the pictures you download; for example, if you name the group "Vacation," the pictures will be named "Vacation001," "Vacation002," and so on.) Click Browse, and select a folder in which to save your pictures.
6.
If you want to erase the images from your camera's memory card to make space for new ones, select the Delete pictures from my device after copying them check box, and then click Next. The Scanner and Camera Wizard copies the pictures from your camera to the folder you specified and then removes the pictures from your camera's memory card.
7.On the Other Options page, you can choose to publish your pictures to a Web site or order prints. If you have finished working with your pictures, click Nothing, and then click Next.
8.On the final page of the wizard, click Finish. Windows XP opens a Windows Explorer window showing the pictures you downloaded from your camera. Your camera's memory card is now clean and ready to store new pictures. If you connected your camera to your computer using a USB cable, disconnect your camera. If you used a memory card reader, return the memory card to the camera.
Your photos are now stored on your PC, ready for whatever you want to do with them, and your camera is ready to take more pictures.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
IF IT HELPS YOU then Your token of appreciation in the form of Four thumbs and testimonial will be esteemed.
Thank you for using FixYa!
3helpful
I am trying to download pics from my Canon G11 to my computer and have it plugged in but don't know what to do next.
Canon PowerShot G11 Digital Camera to computer
6.
Your photos are now stored on your computer, ready for whatever you want to do with them, and your camera is ready to take more pictures.
I hope this will surely help you. Further assistance i am here to help
If you think it was helpful for you then your token of appreciation in the form of Rating as Four Thumbs and a testimonial will be esteemed.
I use pl70. i am having problem downloading my pictures. when i connect my camera to my computer i do not see my pictures, i have even tried inserting the memory card directly to my computer and i still...
1) Using new memory card. first connecting memory card to computer and format. and insert memory card to camera. making single shot. then connecting computer you see picture.
Memory card formating in camera may be not working computer or other device.
2answers
I need to know how to get my pictures on to my computer from my camera. do i need a disk. my computer don't have a hole for the chip. i do have the wire to connect to the computer. how do i go about...
To import pictures and videos from a digital camera
  1. Connect the camera to your computer by using the camera's USB cable.
    samshameem_2.jpgConnecting a camera to a computer with a USB cable
  2. Turn on the camera.
  3. In the AutoPlay dialog box that appears, click Import pictures and videos using Windows.
  4. (Optional) To tag the pictures, type a tag name in the Tag these pictures (optional) box.
    By default, the folder name includes the date the pictures and videos are imported and the tag name.
  5. Click Import.
    A new window opens and shows the imported pictures and videos.
2answers
How do i get the internal memory pictures onto my computer?
Simply remove the memory card from your camera before connecting the camera to your computer. The computer will then see the camera's internal memory instead of the card memory, and you can copy the pictures over.
If you have been accessing your pictures by removing the card from the camera and placing it in a card reader attached to your computer, then this won't work for pictures in the internal memory. You will need to use the other method, connecting the camera to the computer with the USB lead.
The pictures from the camera not show in the computer
Try NOT connecting your camera to your computer.
As I connect the camera to the computer, the recent pictures I to
Nothing is wrong. The file names of the recent pictures probably duplicate those of your old pictures. Your computer is probably caching the images associated with those names until you double-click on them.
Since you declined to specify the type of computer and the software you're using, I'm afraid I can't tell you how to clear the cache. I also assume you're not really connecting your 35mm SLR camera to your computer.
May 15, 2010 • Photography
1helpful
I want to download my photo's from camera to hp laptop
After you take pictures with your digital camera, you'll want to copy the pictures from your camera to your computer so you can print them, share them with others, and back them up for safe keeping. Once your pictures are on your computer, you can erase them from your camera, freeing up memory so you can take more pictures. You can also view your pictures on a larger screen and decide which ones are worth keeping. Some digital cameras come with software that helps you copy pictures from your camera to your computer. You can use this software, but you don't have to. Windows XP can copy pictures to your computer without requiring additional software. Here's how to copy your pictures using Windows XP: 1. First connect your digital camera to your computer. You can do this in two different ways: ?Use a USB cable. Most digital cameras come with a cable that connects the camera to a USB (Universal Serial Bus) port on your computer. ?Use a memory card and memory card reader. A memory card reader is a piece of hardware that plugs right into your computer. You remove the memory card from your camera and insert it into your memory card reader, similar to the way you might transfer a file between two computers using a floppy disk. Tip: It's usually faster to use a memory card reader to copy your pictures than to connect your camera to your computer with a cable. 2. Once you've connected your camera to your computer or inserted your memory card into your memory card reader, Windows XP will detect the connection and ask you what you want to do with your pictures. If you connected your camera with a USB cable, click Microsoft Scanner and Camera Wizard, and then click OK. If you are using a memory card reader, click Copy pictures to a folder on my computer using Microsoft Scanner and Camera Wizard, and then click OK. 3. When the Scanner and Camera Wizard appears, click Next. 4. All of the pictures on your camera (or in your camera's memory card) are now displayed on the Choose Pictures to Copy page. By default, Windows XP selects all of the pictures for downloading. If there are pictures you do not want to download, just clear the check box next to those pictures. At this stage, you can also rotate pictures that you took while holding your camera vertically. To rotate a picture, click it, and then click either the Rotate clockwise or Rotate counterclockwise button on the lower-left side of the page. When you have reviewed the pictures for downloading and rotated your vertical pictures, click Next. 5. On the Picture Name and Destination page, type a name for the group of pictures. (This name, plus a number to differentiate each picture, will be applied to each of the pictures you download; for example, if you name the group "Vacation," the pictures will be named "Vacation001," "Vacation002," and so on.) Click Browse, and select a folder in which to save your pictures. Tip: Create a new folder for each group of pictures you download. 6. If you want to erase the images from your camera's memory card to make space for new ones, select the Delete pictures from my device after copying them check box, and then click Next. The Scanner and Camera Wizard copies the pictures from your camera to the folder you specified and then removes the pictures from your camera's memory card. 7. On the Other Options page, you can choose to publish your pictures to a Web site or order prints. If you have finished working with your pictures, click Nothing, and then click Next. 8. On the final page of the wizard, click Finish. Windows XP opens a Windows Explorer window showing the pictures you downloaded from your camera. Your camera's memory card is now clean and ready to store new pictures. If you connected your camera to your computer using a USB cable, disconnect your camera. If you used a memory card reader, return the memory card to the camera. Your photos are now stored on your computer, ready for whatever you want to do with them, and your camera is ready to take more pictures. As with any important files, it's a good idea to make backup copies of your photos, in case anything happens to your computer
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
