20 Most Recent
Panasonic Lumix DMC-FS3 Digital Camera Questions & Answers
I have a Lumix DMC-FS3 camera and if I don't put a
First of all, forget about using the built-in memory...it's very small. Does your camera work properly when a memory card is inserted? You could also go into the setup menu to "reset". That would set your camera back to factory defaults.
SOFTWARE DOWNLOAD
Hope this is what you are looking for, as this the only reference I found: http://av.jpn.support.panasonic.com/support/global/cs/dsc/download/FT3_TS3/
Free software download dmc
The best way to download pictures from your camera to your computer involves removing the
memory card from the camera and plugging it into a
card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa (
http://picasa.google.com ).
