Panasonic CT-36D32 36" TV Logo
dennis turnage Posted on Apr 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The pip got stuck using a universal remote..i cannot clear it no matter what button I use
Pip stuck using universal remote..i cant clear it no matter what
Level 3:
Top Expert:
  • Panasonic Master 76,851 Answers
  • Posted on Apr 07, 2012
Panasonic Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008380
Points
237762
If you can access the Menu options with your present universal remote, get into it, and surf thorugh picture adjustment and PIP adjustment screen, and set the PIP option to OFF. If you can't access the Menu option with your present remote control, there is no other way to do this without its original remote control.
1 Related Answer
Anonymous
  • Posted on Jun 10, 2009
SOURCE: i can remove the pip setting
i have the same problem!!! i was using a comcast on demand remote!!! it has been on the screen for 2 weeks! WTH!!!!
Please advise how to turn the PIP off w/out the factory remote. Thanks
Without its original remote control, you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
https://homenol.blogspot.com/
https://electrohelponline.blogspot.com/
https://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
I have a protron pltv 4250. I don't have a remote control and the tv is stuck on pip. so i have 2 screens one shows the tv program and the other screens stays blue. What can I do to fix this...
Few universal remotes will provide functionality to any but the most basic of functions.
PIP only functions properly when being used with HDMI.
I feel you will need to buy a dedicated remote. I found some on Amazon for a reasonable price.
Fisher/sanyo 37" tv. when I
Hello
If you are using a Universal remote control with this set, some button functions won't coincide with the display. If you are using its original remote control, the contacts inside the remote control is dirty or dusty. You have to open the remote control and clean its contact pad and printed circuit touch pad with rectified spirit or medical quality turpentine. Never use petrol of such hard solvents to do this, becuse they will damage the rubber parts of the remote control. If it is a universal remote control doing this will be of no use. It will behave only like this. OK.
I want to load my tv code from my vizio on my remote for my 321
I used 0178 to program my universal remote. You can also try 10056, 10178,10864,10885,11756,10056,11758, and 11499. Then you can try by dropping the "1" from the front of these codes.
Most good remotes have a programming function if this does not work, where the remote will "learn" the proper code.
The actual button remote codes are as follows:
0 00117
1 00121
2 00119
3 00123
4 00116
5 00120
6 00118
7 00122
8 00245
9 00249
Vol + 00183
Vol - 00187
Mute 00057
Channel + 00181
Channel - 00185
Power 00053
Enter 00164
Last 00247
Menu 00171
Guide 00244
Up 00168
Down 00166
Left 00170
Right 00037
OK 00164
Sleep 00054
PIP 00197
Info 00251
PIP Swap 00198
PIP Mode 00199
Exit 00216
Audio 00059
Input 00090
Wide 00138
TV 00110
AV 00105
Component 00231
HDMI 00174
MTS 00055
CC 00025
Zoom + 00165
Zoom - 00169
Freeze 00200
RGB 00253
PIP Ch + 00196
PIP Ch - 00203
PIP Input 00199
PIP Size 00201
Good Luck
I am using a universal remote and must have pressed a wrong button. I now have PIP and cant get rid of it. the tele is tevion Model TPDP42P
The procedure to remove it with the remote is simple, it's a single button on the remote that allow to toggle it on and off.
The PIP function on generic/universal remote is often not the same as on the original one. PIP is considered an advanced feature.
Unplug and then turn back the unit ON, after few minutes, say 30 minutes. If the problem persists, then toggle the buttons on the remote, unless send me a pic of the remote so that i could tell you the button.
Note - Sometimes, this is a problem in TV as well.
Let me know, once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
2helpful
2answers
PIP won't turn off
I solved this problem by pressing SHIFT + 1
91helpful
2answers
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
23helpful
8answers
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
