Must enter the engineer mode. Turn the machine ON. Wait until you see the "Select user" screen.
1 - Press and hold the key to increase the incline and the key to decrease the speed for 3 to 5 seconds.
2 - Use the arrows to increase speed to get to Eng3 program (or the arrows next to the Enter button).
3 - Press "Enter"
4 - Then press the green start button until KM appears on the screen.
SOURCE: converting kph to mph
press and hold the stop button while placing the key on, then release and hit speed + or - I don't remember which right now. One turns the store demo on/off and the other is for mph/kph
SOURCE: change speedometer readin on elite 507 treadmill from mph to kph
I know this is an old thread, but if you are still trying to change between mph and km, then follow these instructions.
The setting is changed by a switch on the console circuit board. Unplug the power cable. You will need a medium philips screwdriver. The console is fixed to the frame with 4 screws, climb under the console and remove 2 screws from the top and 2 screws from the bottom. Get back up and lift the console up slightly making sure you do not dislodge any cables from either the left or right-hand side of the console. Look under the console from the left-hand side, in the middle of the circuit board you will see a small slide switch (silver casing with black slider), slide it to the other position. You will see next to the switch the letters mph and kpmh. gently reseat the console, put the 4 screws back in, the console should now display the speed in kmph when you plug it back in and turn it on.
All the best
