Avanti X-Fit 2 Treadmill: Speed Calibration
follow the steps and fix it. God bless you
The Steps for Newer Style
Console Calibration
1. Locate the calibration area on the rear or underside of the console
(a hole, near the console's center, that goes through to the electronics board.
(This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for
the cal button (will click when pressed).
3. Press the button 2 times (with the pencil
eraser). The first click should show CL11 in the console, the second
click should show CL21.
4. If the process was done correctly, and CL21 appears in the
console, you are in "calibration mode." The next few
steps consists of pressing buttons on the console and observing
settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window
and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in
the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in
the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and
9. Press ENTER. CL26 should display in the TIME window.
You should then see the letter "E."
10.
Press ENTER. You should see
"SS" or "55" in the console.
11.Push the STOP/START button. For safety, at
this point, you should step off, or be off, the treadmill.
12.
Push the ENTER button. The walking
belt should start to move, accelerate to maximum speed, then stop on its
own.
13.
When the belt stops, the
incline should self test by raising to its highest incline
position, then lowering back down to its lowest position.
14.
Once the incline test is complete,
push the POWER button 2 times. The unit should shut off and the console
should go completely blank. If this happens, the treadmill is
done calibrating and is ready for use.
15.
If the letter "F" appears in
the SPEED or INCLINE window when the power button is pressed 2 times, the
treadmill is indicating a failure somewhere either in the SPEED or INCLINE
(depending on the window the "F" appeared in). Troubleshooting
the failure would be the next step.
