This is a fault with the TOP249 switched mode power supply controller. I had the same problem and freezer spray on this chip on the power supply card started it workig quickly. Ageing of the chip has reduced the temperature sensing at which thermal shutdown cuts in. Bought a new chip off ebay for £4. Took out old one and fitted new one. Problem solved.
SOURCE: picture freezes, dvd wont play or starts stops continuously
the lens on laser needs cleaning manually never use disc cleaners ever
SOURCE: dvd
This is problem is due to the power card problem so you please replace the power card and try with this surely you can resolve your issue.
