sounds like the barrel has jammed try turning it by hand to see if its jammed if so then it will need to be serviced by a lic tech if the barrel is free turning then i would say it has broken its belt the sqeaky noise would be its bearings wearing out putting the barrel out of alyghnment this too will need replacing
A lot of pads are unfortunately. They will become a little better after a few hours of riding as they do "bed-in" a bit but the longer wearing the brake pad is the noisier it will usually be.
Try oiling the pull bearings. If you can determine that the noise is in the motor, try nelsonappliance.com. They have replacement motors for your fan for less than $20.
the problem is with its motherboard .. i too had the same problem..
ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Most probably the bearings heating, which in turn heats the rubber seals and causes the belt to slip. If there is no noise of metal on metal, you may be able to grease the bearings to get some more life out of them. Taking the drum out is not an easy job though.
my dryer has an awful squeak , it usually starts when the cool down cycle begins and when heavier loads are put in
