Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
You may need to update the firmware on your CradlePoint. Newer firmware supports the release of new modems, which you might have a version of firmware on your CradlePoint that does not "know" your Time Warner USB stick.
Here's how you update the firmware: http://knowledgebase.cradlepoint.com/questions/13/Updating+the+Firmware+on+your+CradlePoint+Router
You should be able to connect wirelessly from your Mac to your Cradlepoint router to obtain this information whether or not the phone is actually connected.
With your router powered up and operational, click the Airport icon on your top menu bar and turn your Airport on. Then click it again and watch for your Cradlepoint's wireless network name to appear. Using whatever WEP or WPA password you previously established, connect to the Cradlepoint.
Now under the Apple menu, choose System Preferences / Network. Select Airport, Advanced, then TCP/IP. (In releases other than Leopard, these choices may differ.) Look at the line marked "Router." That is the address you have to browse to in order to communicate with your Cradlepoint.
