Casio Exilim EX-Z3 Digital Camera Logo
Bob Shishksa Posted on Oct 14, 2006
Casio Exilim EX-Z3 Displays turns off when taking a picture
I have a Casio Exilim EX-Z3 and the LCD screen works fine when looking at pictures ortaking video. However, when switched to Camera mode, the diplay shows what the camera is pointing at for about 2 seconds, then goes black. I can still take pictures and view them, but this is very annoying. Anybody know what the fix is? Mark
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 29, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
255
Points
I have the exact same problem. Casio wants the camera mailed in and charges $79 for a new LCD screen (if that is the problem). Any other suggestions?
I cannot delete picture or take pictures on my Casio Exilim camera. I get "The card is locked" message.
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Picture color on screen is all screwed up
The LCD might be the problem ....... I will have to have a look at the pictures for commenting further .....
System error when turn on my CASIO EXILIM EX-Z3
A system error is a major error that needs to be sent in. There is nothing that we can do at home to fix that one. Sorry.
Casio Exilim z75 - unable to take pictures
Try shutting off your flash and see if it still does that. It sounds like you have a problem with your flash not charging correctly. You can try resetting the camera but I doubt if that will help. I would try just shutting the flash off and see if that would help.
Blank Screen
ok casio luver you have eather a broke lcd or a damaged main board. visit www.digitalcamrepair.com for more help.
2answers
Casio camera LCD screen broken?
There is a guy in South Carolina that sells used Casio parts. I got a LCD for mine and it works fine. I think his email is [email protected]
3helpful
2answers
Lens error
This is the lens focus gears. They are either knocked out of alignment, or debris has jammed them. The good news is it can be fixed....Casio most likely won't help. Hint...google my user name.
Casio EXILIM ZOOM EX-Z60 problem with not being able to get the LCD working after dis-connection and re-connecting the connectors
The LCD will not show the picture until you put the ribbon all the way inside the connector
Hope this helps
Joe
2answers
Casio Exilim EX-Z3 not working (accidentally dropped on carpet)
Does the lens retract when you shut the camera off? Or at least press the On/Off button?
It doesn't sound like there is a problem with the lens if your buttons aren't working, it sounds mostly to me that a cable got dislodged and that has disabled your buttons and zoom switch.
You can try sending it to this guy - www.darntoothysam.com he might beable to help you.
3answers
Casio Exilim EX-S500 screen is black when turned on
you camera shutter is stuck at close position, you will need to open
the thing up to repair.
As for the totally dark screen, either your LCD or driver board is bad. You will need to open and replace the broken part.
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Casio Camera Expert? Answer questions, earn points and help others
