While watching TV, all of a sudden these vertical lines appeared on the screen. The picture was still visible, but seemed to be behind the vertical lines. The vertical lines were different colors, magenta, green, red. They were not extremly close together, more spaced out, but across the entire screen.
SOURCE: vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
I will need the model number of your set to assist you with the most probable cause of the problem.
