installing LAN Card driver either u need to installed manual or automtically .
1. automatically each vendor have its own driver for the lan driver card . so once u download the driver applicattion u just double click and follow the steps it will detect the lan card.
2. manualy u have to extract the the driver file and put it in specifict folder then u have to right click on my computer then click on management the click on device manager then right click on the Lan device which will be makrd yes yellow quesiton mark then u have click on update the driver and select browse my computer to install the driver and then give the path o exit extracted folder you will be done.
u can remove your lan card drive from add remove option in control panal
if u have lan card problem open your cpu diconnect lan card and clear its golden connector and clean pci slot which in on mother board then again plug it and reinstall lan drivers if problem not fix try with replace new lan card 100 percent it will help u
The
Network LAN driver is specific for each LAN card. You can download the LAN
card driver from the manufacturer's WEB site. I could have given you the link
to the manufacturer's WEB site but since you have not provided the make and
model of your LAN card I cannot assist you.
The Network LAN driver is specific for each LAN card. You can download the LAN card driver from the manufacturer's WEB site. I could have given you the link to the manufacturer's WEB site but since you have not provided the make and model of your LAN card I cannot assist you.
You use built in Lan Card
or Lan Card which is in PCI slot.
1st you know the name of the Lan Card.
But You can download different type Lan Card Drivers.
Lan Card Drivers
Either the LAN card is faulty or the LAN driver is not installed and/or not configured properly or the LAN cable is faulty.
Check Device Manager to see if the LAN driver is installed, working and enabled. If not then re-install the LAN card driver.
If the LAN driver won't install or detect the LAN card then it maybe faulty and needs to be replaced.
Try a different LAN cable.
Is all the LEDs on in the modem?
Try rebooting the modem (power it off for 30 secs and power it up again).
