A
Anonymous Posted on Feb 24, 2012
Konica minolta bizhub 363 error message c-2201
Copier konica minolta bizhub 363 displays error message/code c-2201
Norman Weimar
Level 3:
  • Minolta Master 7,035 Answers
  • Posted on Feb 19, 2015
Norman Weimar
Minolta Master
Level 3:
Answers
7035
Questions
Helped
1914171
Points
11960
Remove the toner bottle let machine thur its paces when it says install toner bottle install correctly
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Feb 02, 2008
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Anonymous
  • 589 Answers
  • Posted on Feb 10, 2008
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
steven brickhouse
  • 19 Answers
  • Posted on Apr 16, 2008
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Anonymous
  • Posted on Dec 22, 2008
SOURCE: i wanna know how to reset the maintenance time konica minolta bizhub 750
how do i reset an imaging unit on a konica c252
Anonymous
  • 210 Answers
  • Posted on Jul 09, 2009
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Code 61
is it a network error code.
Could mean FTP TX interruption or SMTP connection rejection
check ftp settings are correct
http://www.manualslib.com/manual/421595/Konica-Minolta-Bizhub-223.html?page=63
Could mean smtp problem check settings
http://www.manualslib.com/manual/421595/Konica-Minolta-Bizhub-223.html?page=216
Bizhub 363 error code c-fa16
MFPB board, but might try having a tech come and reflash the copier operating system software
1helpful
C-1116 message on Bizhub 500
In Konica minolta Buz C550 copier teh C-1116 error code refer to :
output OP center press transportation motor drive.Check the transmission driver mechanical components(gears,rollers).To reset press and hold on the Utility key and turn ON the copier,wait to displayed Trouble reset message,release the Utility key ,touch the message,turn OFF the copier ,wait 2 minutes and turn ON.
Konica minolta 363 error message c2201
Toner bottle failure to turn. Shut off the machine remove the toner bottle, turn on the machine with the bottle inside it, wait for the machine go thru its paces when it ask for the toner install in correctly if the knub on the bottle is damage get a new one . if this does not work get a tech to look at it either the motor is bad or worse the control board is bad$$$
reset open close side door
Konica minolta 363 error message c-2201
remove the toner bottle reinstall when machine ask for it.
replace the toner bottle
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it is damaged you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
