20 Most Recent
Konica Minolta "Minolta Bizhub 363 Copier, Printer, Scanner" Questions & Answers
How to resove trouble code c-3823
Sir/Mam, turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it see a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!! Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
When trying to print more than 10 copies at a time, error code c-2558 appears and it stop printing..means it can only print 9 or 10 copies at a time but not more than that then error code appears
Code
C2558
Description
Abnormally high toner density detected TCR sensor
• TC ratio in the developing unit, which is determined by toner replenishing amount control mechanism, is a predetermined value or more for a given number of times consecutively.
Remedy
1 Make sure that the following counter is cleared at the developer replacing. [Service Mode] - [Counter] - [Life] - [Developer Use Time] 2 Perform image troubleshooting procedure if image density is low. 3 Reinstall developing unit. 4 Reinstall toner bottle. 5 Check the contact of developing unit for proper connection and correct as necessary. 6 Check the connector between TCRSB CN29-relay CN28-PRCB CN24 for proper connection and correct as necessary. 7 Check the connector between M3-PRCB CN8 for proper connection and correct as necessary. 8 Check the connector between M4-relay CN13-PRCB CN8 for proper connection and correct as necessary. 9 M3 operation check. 10 M4 operation check. 11 Change developing unit. 12 Change TCRSB. 13 Change PRCB.
Message that say replce developer
Sir/Mam,
That means that the Developer kind look like toner but is different need to be replaced 110,000 copies along with the drum do NOT YANK OUT THE IMAGE UNIT on THE RIGHT SIDE THERE IS A SMALLL PLASTIC COVER ATTACHED WITH ONE BOLT AND CONNECTER UNDERNEATH THE SMALL CONNECTOR IF YOU DONT, ASKING FOR BIG TROUBLE. Have the developer and drum replaced by quailed technician. Btw, I’m available to help over the phone in case u need at
I am having L code errors on our Konica Minolta Biz Hub 363
Sir/Mam,
#10 Transfer roller needs replacing sponge looking roller right side of the of the machine when you open to remove paper jams.
# 9 Developing unit needs replacement that the part that holds the drum and developer/toner. IF YOU YANK THIS UNIT OUT WITHOUT REMOVING THE LITTLE COVER ONE BOLT and DICONNECT THE CONNECTOR. BIG TROUBLE, going to cost a lot to repair.
#8 PAPER DUST REMOVER the device that collect paper dust yes paper does produce DUST. Just before the sponge roller
#6 IS Warning that the developer has not been replace inside the drum cartridge. SEE #9
#4 Drum need to be replaced.
Really have to watch for all of that sir/mam. Btw, I’m available to help over the phone in case u need at
Hi
I need a help i hav error code C-8003 on konica Minolta B951. Please assist.
Thanks
Podtermistor wa?ka utrwalaj?cego nie
wykrywa wymaganej temperatury w ci?gu 30 sekund.
po rozpocz?ciu cyklu rozgrzewania; dlatego
kopiarka nie ko?czy cyklu nagrzewania.
• Temperatura wa?k?w utrwalaj?cych nie
osi?ga wymaganego poziomu nawet po
up?ywie ustawionego czasu podczas cyklu nagrzewania.
Sprawd?, czy lampka utrwalacza H1 zapala si?, gdy g??wny
wy??cznik zasilania jest ustawiony w pozycji W?., w razie potrzeby popraw lub wymie?.
Sprawd?, czy H2 w??cza si?, gdy g??wny
wy??cznik zasilania jest ustawiony w pozycji ON, i w razie potrzeby popraw lub wymie?.
Sprawd? instalacj? TH1 i TH2 i
w razie potrzeby popraw lub wyczy??.
Sprawd? dzia?anie TH1.
Usu? CN80 (4P), a nast?pnie sprawd?, czy rezystancja
na CN80-2 i -3 na termistorze jest
niesko?czona.
5
Sprawd? dzia?anie TH2.
Usu? CN81 (4P), a nast?pnie sprawd?, czy rezystancja
mi?dzy CN81-2 i -3 na termistorze jest
niesko?czona.
6
Sprawd? ci?g?o?? H1.
W razie potrzeby popraw lub wymie?.
7
Sprawd? ci?g?o?? H2.
8 Zmie? PU1 - -
9 Zmie? PWB-A
HOW TO RESOLVE CODE C-2221 KONICA MINOLTA BIZHUB C5500
1.The terminal for the first transfer pressure/release sensor is not connected properly.
Reconnect the terminal.
2.Failed PS15 (p/n 08AA 8551 2).
Test photosensor, PS15, in the I/O State Confirmation Mode, 48-0HIGH = home position or LOW = Other than home position by activating M19 (p/n 08AA
8003 0) transfer pressure/release motor, 48-0, 48-1, 48-2, or 48-3. Replace thephotosensor or motor as needed.
3. Possiblefailed Transfer/Pressure Release motor (M19).
Check the operation of the motor(p/n 08AA 8003 0) in the I/O State confirmation mode for proper operation with code 48-0; this should rotate the motor
constantly. Replace motorif needed.
Also check for possibleopen ICP fuses, ICP3 (5V DC)and ICP4 (24V DC) on the AC drive board (p/n A03U H520 01). Replace the drive board as necessary.
SPECIAL NOTE : Solution contribution by KMBT (Japan) and Freddie Burnham, Production Print/SSD
