Hi can you give us details on the make & model of the bike as there are quite a few out there !Hi can you give us details on the make & model of the bike as there are quite a few out there !
I would suggest you look at it as one circuit at a time. I don't know what is on the bike like for example, horn, tail light, head light, brake lights, you get the idea. the main thing to know is that the wire from the magnito is simply grounded to shut the engine down. So wire it that way, either with a key switch or push button, or toggle switch kill switch.
You can goggle for a wire diagram online. Also check your switch first trace the wires down to your starter. write down the colors. Check for breaks inside of thewire harness every wire. mite be broke in the insulation on wire also check your fuses. If you can jump start it and it stays running and you can cut it off. its in your primary wiring not your secondary
Just call the mechanic and get it fixed, because if any wiring if connected wrong then it may causes a big damage than at this condition result in more expenses. Classic Motorcycle
i need wireing diagram for a yamoto 150 or 200cc quad
wiring diagram for bandicoot rtv200
i need wiring diagram for a blaney fx 70 cc quad can anyone HELP!!!
i need wiring diagram for 250st chinese 2x4 quad bike twin cylender
