Clock did not work. replaced clock. it works fine. but after setting selector switch to clean and thermostat to clean, pulling lever lock to right and pushing set button twice, the elements do not come on for the clean cycle.
not in auto or in delayed. auto is illuminated on clock, but unit just does not seem to heat up.
all other functions work properly. bake, broil, convection, temperatures,
glass top w/ radiant heat, clock, oven light, circ fan and conv. fan.
it looks like a small black box attached w/ 2 screws to the back of the t-stat has gone bad. it is about 1/2 inch x 1/2 inch x 1 1/2 inches lng
with one lead to one of the door interlock micro switches and one to the lock/oven/clean indicator light. what is it for? thermal overload? where can i get one. so far i have only found it attached to the t-stat for $150+.
....any one else know of other resource?
indicator light
SOURCE: Jenn Air Range SVD48600W (Circa 1998?)
Why are the oven indicator lights flashing?
Answer:
When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
SOURCE: Jenn-Air S136 Grill-Range--auto clean not working
Selector to Clean
Temperature to Clean
Move lock lever to the right
Press the enter button Twice
SOURCE: bake element burned out on
HI,
You should have 120 to the element when not in bake mode, while in bake mode you should have 220 - 240 volt. Sounds like you lost a relay to send the additional power to the element, or you have a High Limit thermostat which could be open. This is a safety device to protect the unit from over heating, this only goes if temperatures increase higher the safety levels, normally set about 200 degrees or so along the air flow channels. I would trace from the elements to the clock and find the missing source of current.
I hope this helps
Be safe with electricity......
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Testimonial: "Perfect! it was the high limit thermostat.Thank You for your help"
