SOURCE: Canon pixma MP600, error code 5010, what does it mean
There are a few things you can try:
The overall issue with error code#5010 is a scanner malfuntion. If the problem returns, check the ribbon cable as it runs from your scanner to the main logic board. If all is secure and you still have the problem, the printer may need a new logic board.
Testimonial: "Thenk you very much for your assistance, I will try your solutions. regds Robert"
SOURCE: Canon PIXMA MP140 error code E 2
error E 2 =>
The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
SOURCE: Any help with a Canon Pixma MP 250 P2 Error Code?
I found you a site where you can download the latest drivers to install at the link below Good Luck
http://support-au.canon.com.au/EN/search?canonsearch=1&lang=EN&category=All-in-One Printers&series=All-in-One Printers&model=PIXMA MP250&menu=Download
Thank you. I will do that.
