I just got this samsung syncmaster 910t monitor that displays the image at full color with brightness but only for a fraction of a second and then goes black again. Power light is on and everytime I press the "source" button it blinks a small white square with "digital" written on it on the top left corner follow by the full image with "analog" on the top left screen again. Any suggestions? It seems to be an incredible screen and there is no way I could afford one of these so I would REALLY appreciate your help! Thanks!
I've had same problem and I fixed it!
With good CCFLs, clean supplying voltages, all good capacitors and resoldered junctions, the backlight still turns on for fraction of second and goes off.
It is in the Power Supply / Inverter board. In the Inverter part there are two dual n/p-MOSFETS U3 and U4 (models STS7C4F30L, SO-8 packages). I've found they both have too high ON-Resistance (perhaps due to age and constant overheating). All you need to do is to replace them. I've checked many models and found closest by Rds and IDcont (continuous drain current) are IRF7389, you can find distributor by findchips.com, but I've bought them at newark.com, they're cheap.
The hardest thing was to unsolder old chips, they are glued to PCB and because of overheated material under them, the copper could easily go apart. Therefore, the best is using fine tips cutters, cut off all legs one by one and then take chip body off the PCB and take legs from pads by iron. That's all you need. After that my monitor started working as new even with old CCFLs. Good Luck!
I found a site that sells your (our) part: samsungparts.co. Look up that model number for the power supply under "Part #" and it seems to run about $60-70. I'm probably going to order one and give it a shot as a drop in replacement.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Yes, it's a used monitor. I have done the flashlight test now and I can see the image displaying and all the front buttons are responding. I have opened it and all the capacitators seem intact and well welded. I don't have a tester now but I have ordered one. What should I check then? Thank you very much for your help by the way :)
Sure thing! In the board you can read P/N: BN44-00106B on the top corner and Model: PWI1704SG (B) Rev1.0 if that helps.
I have sent you some hi-res pics to your e-mail.
Thanks for your help!
P.S.: you are F A S T in answering! :)
I've sent you 3 bigger images to your e-mail address. my e-mail is [email protected]. Didn't you get them?
Thanks
Hello, did you ever fix this problem? I have the same model and after 4 years (3 is the maximum warranty service), one day, I booted up and the inverter went out. Still blinks my login screen once, but then goes black. The only difference is my PSU/inverter is listed as PWI1704SG(A) Rev 1.0.
Need help, i hawe same problem.
Thanks.
Larger picture will help (I'm having a hard time seeing the plug to the
video board). What you have is a combination power-inverter board on
this monitor and a 4 bulb screen.
Can you post a picture somehewre or email me one.
That will give me a better idea as to what you actually have in that monitor.
[email protected]
I assume that this is a used monitor ?
Do you have the capabilities to open it up and a tester if needed for testing voltages ?
It sounds like a typical lcd monitor power- inverter board problem.
